Magic chef oven 6498vrv
My magic chef oven model#6498vrv is not maintaing proper temperature. I have replaced the oven sensor. Then checked oven temperature with a thermometer and temperature is off by 200-300 degrees. Last year I replaced the touch panel , which fine. I have searched for other parts that might be the problem, I found Relay board
Part Number: AP379876 made by MAYTAG could this be needed? Any other suggestions or parts would be greatly appreciated. I’m sure there is a thermastat somewhere built into a part, could that relay board be it ?
Thank You Michaelman31
Thank you Gene.I will order the control panel .
Pull the back freezer panel off and check and post the frost pattern.
