Temperature Issues Have Gotten Progressivley Worse Over Time. At First It Would Take Very Very Long To Heat Up. Digital Display Would Say It Was Up To Temperature But It Was Not Even Close. Eventually It Would Get There. Then It Started Clicking Off While Preheating, Never Able To Achieve Desired Temp. Now Nothing. I Turn It On And It Clicks Right Off. Never Use The Broiler So Don’t Know If Any Of That Is Ok Or Not. Stove Top Is Good. Advice Appreciated. Thanks
you would need to replace the clock control board. the model # is not fully complete. after the 36tx, there should be another few letters like, on after it. take a look, and i will give you are part #. tom %url%
