my washer dose not work at all, pull the start knob and nothing with the lid down. and the water turned on no noises just nothing dryer protion is working do you think fuse in lid switch or the lid switch ??? or something else
Would it drain/spin if you advance the timer manually to that point?
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=44572
— Begin quote from Gene;483767
Here are the breakdown diagrams and Replacement parts for MAYTAG LSE7806ACE STACKED LAUNDRY- ELE | AppliancePartsPros.com
try several settings nothing ,wont drain, spin nothing
