First,…machine will not run now…it makes a motor humming type sound. We are thinking that the pump is locked up and the belt is showing wear.
So, first…should we replace the pump,…is it possible something got down in the pump and locked it up. That would explain the noise and why it won’t start, and why motor noise…because motor turns but belt doesn’t…we think. So…there’s the Aeeeeaaeee sound like the motor is one…but nothing will turn or go on.
How do you take off the front panel? There are two clips on the bottom that hold the panel on,…but we can’t figure out how to get them off without damaging the panel.
What would you suggest doing?
