Washer was full of water timer was all the way to end. I put timer back to spin cycle but just made buzzing sound. I then tried different cycles on dial and nothing happened. Eventually buzzing sound went away but I then smelled something burning
Open it up and check for something caught in the pump or the drain hoses or between the tub and basket. Hopefully that is all it is.
I finally drained (by hand) washer. Fill and rinse works but not spin. The timer switch just hums when on cycle. I’ll pull apart today and look for any obstructions
Ty
