Maytag 2000 series will not fill on any wash cycle, only rinse cycle
We started getting LF code on the occasional wash cycle 2 months ago. When that occurred, we’d cancel the load, power the washer on/off and restart it, usually with success. We checked the inlet valve screens and replaced the valves. The problem seemed to be gone for a week, then came back. We called someone out for repair and they flushed the drain line. The LF codes went away again for a few days, then came back. The same repair folks came out yesterday and said the problem is now likely the board. However, they suggested running the Clean cycle to rule out detergent buildup as the root cause and then unplug the washer for 2 hours. The Clean cycle wouldn’t run without LF, so we ran the normal cycle with hot water and Affresh twice. After 2 hours, we plugged the washer back in and the normal cycle started up again, but then my husband powered the washer off after it filled for only a few seconds without hitting cancel and letting it drain. :mad: Thereafter, the washer would only spin and not fill with water on any cycle - almost like it thought it was already full of water. The rinse/spin/drain cycle is the only one that would allow water into the washer.
I saw some suggestions about replacing the pressure level switch. I took mine off and blew into it and I only heard 1 click, which I think means that it is faulty. My question is, would a fault pressure level switch also cause the washer to not fill at all on any cycle? But still allow the rinse cycle to fill?
Operating on the suspicion that the pump trap must be working properly to reset the pressure level switch, I had my husband check the pump trap. He said it was completely full with lint, like a ball the size of his fist. I can’t believe the appliance repair people we called flushed the drain line but never bothered to check the trap? :confused:
