Maytag A610 top loader out of balance
Have an old Maytag that seems to easily stop due to out of balance load. I can only think that it is the tub centering springs that may need adjusting ( tightening?) or replacing. They are not broken or loose.
Is this a reasonable diagnosis, or is there something else likely to be causing the problem? Everything else seems to run just fine, I have replaced the belts a year ago and they seem fine.
Appreciate any insights. If this IS the problem, how do I go about replacing them?
Also, how do I replace the tub damper?
Thanks.
