Maytag Washer out of balance
I have a maytag washer that began to go out of balance during the spin cycle on large loads and eventually on small loads. It basically starts banging against the washer shell and sounds like a thunder storm in my basement. After reading many posts I purchased new springs and a snubber ring from Appliance Parts Pro. The old snubber ring did not seem worn out and there was no white shavings but I replaced it when I replaced the springs. The first thing I noticed was that the tub was much easier to shift side to side than it was prior to replacing the parts, then after a couple loads the washer started to go out of balance again. Is there something I am missing? Is there another tension spring that tightens the belt or upper area of the tub? Or maybe something to tighten the motor. My biggest surprise was that the tub shifted so easily after the fix. Thanks for any help
Steve
