My dryer will not start. I pull the chrome handle out but it won’t kick on. Do I need to buy a new starter and clutch or what?
Does the interior light work when you open the door?
If it does not, check the circuit breakers for the dryer.
If there is nothing wrong, check the thermal fuse (#4 on the [B]Service manual for continuity.
- The thermal fuse AP4037790
Here is the [URL="http://servicematters.com/maytag_library/docs/16023110.pdf).
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170647
