Maytag bake element replacement problem
The lower bake element in my Maytag Gemini Electric Range burnt out (literally blew up). I replaced the element which I purchased from Maytag. The element does not heat up. There is no electricity going to the element. Checked it with a multi-meter. Any idea what else may need to be replaced?
Please give me one good reason why it should not work. If you are interested I shall update you in six months’ time.
Can some one tell me or send pictures on how to uninstall a garbage disposal I have shut everything down taken the pipes off just canot unscrew the darn thing HELP PLEASE:(
They seem to get stuck on there after a while. Gotta use more force. Be careful!
