It’s done this a few times before but now it’s stuck in the on position. The only way to stop it is to unplug it. When I plug it back in, it starts running again without the stopper in place. I’m guessing there’s something stuck that is activating the switch. Do I need to replace the switch or is there an actuator that needs cleaning or replacement.
I have a similar problem, did you have it solved?
Could not be fixed. Spent a bunch of time on the phone with maytag. Clearly they had a flaw in their switch design/part and basically refused to send me the replacement part because I might injure myself as a result of the repair. The best they could give me was something like 10 dollars off a future purchase. We decided we could live without a disposal. Very frustrating… poor quality part, poor customer service
— Begin quote from egizzi;133922
I guess I will live without it as well. I disconnected the electricity connection so the disposal is disconnected now (forever?).
Thanks for sharing your experience with me.
"hot" signal light will not go off whirpool flat top range, large front left burner. need repair part, GR396LXGQ1 thanks liz
