Oven Igniter Stays On
Oven Igniter Stays Glowing,also Must Tap On Burner To Get Lit. But Igniter Stays On. Any Advise Would Be Appreciated.
The oven igniter stays "on" as long as the flame needed to stay "on".
If you have to tap on the burner to let the gas out then it could be a bad igniter or a bad gas safety valve.
You have to measure the current drawn by the igniter to find out exactly which part is bad.
If it’s less than 3.2 amps - replace the igniter.
If it’s more then 3.2 amps - replace the gas safety valve.
Here are the break down diagrams for the Maytag range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=662862&&model_id=45768
We Have A Leak On The Floor Under The Dishwasher And By Looking On The Parts Website It Appears To Be The Inlet Water Valve. Any Ideas How To Be Sure And If This Is Replaced Is There Also Something Else That Should Be Replaced?
Get a small mirror and a flashlight and locate the leak.
Dry everything off and through sight/feel determine where the actual leak is, sometimes a leak can be higher up and it is just dripping from a certain part.
Could be the valve itself (replace it) OR the input line (may just need tightening) OR the output (may need a new clamp).
Also could be coming from the overfill float assembly.
Check the fill level usually machines fill to just below the heating element.
Remove the float cover and clean/check it.
Sometimes crud will build up in this area and siphon out some water.
Leak will be a few drops and only when there is water in the tub.
PS You have a duplicate post. Please delete it if you can as it will just confuse things.
