maytag bravos f32 and ld code
Started with ld code. Installed new interface control board and motor control board due to a few other problems. Now it shows a f32 code indicating the pressure transducer is out. That is within the new motor control board. Installed a new pressure hose too. Still getting the f32 code. Drain pump is less than a year old . have checked both pumps for any obstructions and theyre clear. Even removed the tub to be sure everything was clear. Pump drains when i leave it overnight as if the pressure builds up in the transducer. Only works for washing one load. I am out of ideas here and need help desperately. I even checked the wiring to make sure nothing was visibly damaged and all looks good. What am i missing here? Please help. Thank you.
I have the exact same problem and would love to know if there is a solution. Anyone?
