Maytag Bravos FL code, but fills during diagnostic
Keep getting FL code and not be filling during cycle (i.e., running Normal, tried different cycles same failure).
  • Pressure hose seems good as I can blow through it into tub.
  • Volt test – I get 120v at cold and hot inlet valves but not on all others
    Ran Diagnostic and filled part way up, drained, spun fine no codes during diagnostic.
Thinking maybe one of the routing valve(s) isn’t opening during cycle, maybe controller not signaling right???
On a very tight budget and can’t afford to replace washer and stuck right now…any help would be appreciated. Thanks.
