Problem: Filling and agitation are fine. Most water is drained out, but clothes are too wet after spin cycle.
Following the suggestions from Gene of Appliance Parts Pros, I removed the belt and checked all three pulleys for pump, transmission, and motor. All pulleys were rotating freely in both directions. Both I still ordered and installed new pump assembly and new drive belt (which were replaced in Nov. 2007). I examined both drain hoses (the tub to the pump and from the pump out) and no any blockage was found. However, clothes are too wet after spin cycle.
Anything else I can do, except to hire an expert? Thank you.
Adam
