Maytag dishwasher is not responding
The touch control panel is becoming more difficult to respond when attempting to start dishwasher. What part do I need for repair?
Additional info: We can get the dishwasher to work if we push extremely hard but it takes several attempts.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDB5600AWB
Here is a tech sheet and a manual
http://www.servicematters.com/maytag_library/docs/16023063.pdf
http://www.servicematters.com/maytag_library/docs/16021814.pdf
It does sound like the panel (keypad), Item 1 in the "Control panel" section is going.
The tech sheet shows how to check it with a meter.
Could also be that one of the door switches is just making and pushing on the panel shuts the door enough to activate the switch.
I would try the following first in case pushing hard on the panel is moving the ribbon cable enough to get the unit going.
Unplug the unit
Open it up
Clean the edge connector.
[http://www.servicematters.com/maytag...s/16021814.pdf](http://www.servicematters.com/maytag_library/docs/16023063.pdf"]http://www.servicematters.com/maytag...s/16023063.pdf[/URL]
[URL="http://www.servicematters.com/maytag_library/docs/16021814.pdf)
[LEFT][COLOR=#000000]
LINKS ABOVE RETURN NOT FOUND
[/COLOR][/LEFT]
servicematters.com is no longer an open site.
I have filed a class action lawsuit against Whirlpool for their faulty control panels in their Whirlpool and Maytag dishwashers. Please contact my attorney Eppsteiner & Fiorica Attorneys, LLP at 866.548.8857 and let them know if you own or owned a dishwasher with control panel failures.
