Maytag keeps going out
The control panel went out on my Maytag (MDB8751AWS) under the counter stainless steel DW the first year (2006). They sent me a defective part and then finally one which worked. I had the control panel replaced again last May. It has stopped working again.
The lights across the top which choose the cycle are working but not the touch pad on the front which starts the machine. The display numbers look like they got wet. I would like to open the machine up and try to dry out the panel by leaving it in a bag of rice.
What tool is used to open the door up?
The last repair cost me $276 for a $450 diswasher. :mad:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDB8751AWS
Here is a manual which should help
http://appliancedigest.com/index.php?/files/file/474-16021814-maytag-jetclean-ii-dishwashers-service-manual/
I would not bother with the rice routine.
Just open it up undo the plugs/wiring and then dry it with a hair dryer, just do not get it too hot. Dry it then let it cool down then do it again, do this several times.
If it has water marks/scale on it clean it with an electronics solvent.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
