my dishwasher leaks from the bottom right after the wash cycle starts (after, but not before the tub fills). If I open the door shortly after the leak starts the right side of door near the lower half is wet (the side, or edge beyond the gasket). Therefore, I feel the seal between the door and gasket is bad. However, I took out the gasket and reversed it left-to-right and the right side only still leaks. The gasket feels soft and pliable and I see no notable obstructing deposits or debris.
Thanks for any insights.
Charles
