Maytag Dishwasher
The control panel does not respond when the buttons are pressed. I have replaced the control panel and the door latch assy. None of the lights on the control panel work except when I lock the panel. Only the lock light comes on. I have checked for voltage at the panel and I have 120 V.
Make and model. How old is it?
What was the original problem?
Maytag Dishwasher M/N MDBTT50AWS. Original problem: Dishwasher would not do anything. No lights at control panel.
Thanks,
I replaced the control board and had the same problem. Does the control board come locked out. If so how do you unlock it. I tried doing it with the manual and it would lock and unlock.
David V. Jones
Did the original board let you lock/unlock the keypad or was it totally dead?
No
Sounds like this is working so you know the board is getting power.
Try running the diagnostics.
If no joy check the keypad switches using the tech sheet info.
I did not try to lock out the old board. The complaint was no response with the control panel.
Do you have a link to download the diag and the tech data sheet?
Thanks,
David V. Jones
Yes it was in my first post but at the bottom so did not show up too good
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Schematic%20-%20W10111827.pdf
