Maytag does not rinse/spin
My washer stopped draining/rinsing/and spinning in the Regular and Permanent cycles. However it works fine in the Delicate cycle. Based on the other posts, I have made sure that door-safety switch is working fine.
In these modes, the timer runs making clicking noise, some times little bigger (relay on/off type) noises. But neither it drains nor spins.
If I move it to spin in the Delicates section, it works like a champ. !!
Thanks in advance.
Hi.
Most likely the timer is bad. Also check if you are getting cold water.
The timer 22001026
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=42087
Thank you. Post the results.
Simon.
