I need to replace the motor on my Maytag Neptune Dryer Cabinet. I can not get my hand in from the front to remove the belt from the pullet to remove the drum to get access to the motor.
Can I access the motor from the back? If so how do I remove the cabinet.
If I should get to the motor from the front how do I access the pulley to remove the drum and on the reinstall how would I maintain the belt on the drum and get it back on the pulley?
