[SIZE=4]I need to replace the relay board in a Maytag [/SIZE]MCG8000AWW dryer cabinet. I know I need to remove the drum, but I need to get the belt off the idler pulley. I have the front panel off and you can’t reach the idler pulley from there. Is there an access panel in the back that I can take off so I can reach it? I greatly appreciate any help. Thanks.
Perhaps the following will help.
Here is a link to a manual.
You will have to join the site and be logged in to be able to download it
http://appliancejunk.com/forums/index.php?action=downloads;sa=downfile&id=336;t=1416044669
Sorry just a double post so I deleted the text.
I registered with appliancejunk.com and activated the account, but it won’t let me download the manual. Every time I link to http://appliancejunk.com/forums/index.php?action=downloads;sa=downfile&id=336;t=1416044669 I get a message telling me I need to register or log in to download the manual. I get this even if I’m logged in when I link. If I log in from that page, I can’t get back to the manual.
Try going to the home page of appliancejunk and login.
Then open the link in another tab and try downloading it.
Thanks very much! I got the file and it’s the Maytag service manual, exactly what I was looking for. It showed me how to replace the relay board without removing the drum. I did it and the dryer now works perfectly. Mission accomplished! Thanks again.
You are welcome.
Glad to hear that you are up and running.
