Maytag dryer just repaired, but feels hot
Model Number: hye2460ayw
Brand: Maytag
Age: 6-10 years
Howdy, all.
New to the forum, so be nice!
Maytag dryer: HYE2460AYW
Problem: My Maytag dryer seems too hot to touch in parts of the upper left above the coil. Only a small area feels hot. Most of the top feels normal. I’m not sure what the baseline normal is. So, i’m not sure if this is an issue or a concern. I checked the exhaust temperature, and it’s about 112 degrees.
History: The multi-rib belt in my Maytag dryer recently wore down and snapped. I’m not an expert, but i replaced the belt myself. At first i had issues snapping the drum back into place tightly. took me a few times, but it appears to have a good seal now. The felt seal on the back wall does appear wore down. I’m considering replacing the seal. Could that be what’s making things hot? a bad seal?
The dryer is now drying clothes better than ever!
Twice a year I tear down the dryer to clean the lint (and in the vents as best i can).
So, anybody know if this "too hot to the touch" is an issue or semi-normal?
Thanks for your thoughts!
Chris
