Maytag dryer rerpair
I am replacing the old drive motor on my 35 year old maytag dryer. The new motor replacement is W10410999. My old motor has double yellow wires, red, black, blue and white. The new wiring instructions says to put the grey wire on the 1/4 thermal protector tab and the red (neutral) reterminate to tab 5. Since I have no grey, does the white wire go where the grey wire should? Was the white wire on the old motor part No. 303358 a neutral or not? Do I reterminate both yellow wires to one terminal? Common sense says yes as both are wired together now on one terminal. Is the white wire the L1 and the red the neutral as per the wiring instructions that came with the new motor? I just don’t want to wire it incorrectly an I trust the new wiring instructions are correct. Thanks for your help.
Hi.
The white wire is L1 and it’s going to the 1/4 in terminal of the protector on the left side.
The red wire is a neutral and going to the terminal 5 after you change the terminal to 1/8 in insulated one.
The rest connect according the color code.
Open this link and read Q/A’s. [part]W10410999[/part]
Simon.
— Begin quote from BillandJane;778947
Simon,
Thanks for your help with my dryer wiring. I don’t know if you can tell me, but why is the wiring instructions with the new motor different when it comes to the red and Grey (white) wire placement? BillandJane
Hi.
The manufacturer is working on replacing this instructions at this moment. Sorry for the inconvenience.
Simon.
— Begin quote from Simon / APP Team;778989
Hi.
The red wire is L1 and it’s going to the 1/4 in terminal of the protector on the left side.
The white wire is a neutral and going to the terminal 5 after you change the terminal to 1/8 in insulated one.
Simon.
Just wanted you to know FYI, the above answer did not work for me. When I turned the dryer on it kicked the breaker. So I wired it according to the instructions that came with the new motor, switching the red and white wire and it worked. BillandJane
Hi.
Sorry. My wrong (looked at the wrong diagram).
Thank you for posting the correct answer. I’ve corrected my post.
Simon.
