Have a Maytag dryer that takes many many times to get clothes dry. When you open dryer, it is hot, the thing turns but clothes do not get dry. Help?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=SDE3606AYW
Most common cause is a dirty vent system.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
