[SIZE=3][/SIZE]
[SIZE=3]My dryer won’t start, I omed out every relays and thermal switch, but cannotfind what’s bad.[/SIZE]
[SIZE=3][/SIZE]
Here are your parts, includes a wiring diagram.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=PYE2300AYW
Have you checked the power?
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
If the power is good then unplug the unit and attach/tape one meter lead to the Neutral on the power cord plug and leave it there. Now work your way back through the motor/start circuit till you find the open.
