Maytag dryer no power or light
[SIZE=2][FONT=Arial]I have a Maytag Dryer PYE4500AYW. It will not start and the light does not come on. I tested the thermal fuse with a multimeter and it looked liked it was fine, so then I took the wires off of it and taped them together to bypass it. I plugged the dryer back in and still nothing worked. I thought for sure it would be the thermal fuse. :confused: [/SIZE][/FONT]
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=PYE4500AYW
Looks like the wiring diagram included with the above is incorrect as it is for a gas unit.
First thing to check is power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Thanks for responding. I made a mistake. I tested the the thermostat instead of the thermal fuse. The thermal fuse is no good. I will order the replacement kit for it. What is the best way to replace this? Do I have to take the tumbler out to do it?
