Maytag dryer
My maytag dryer no power and no light. I check thermal fuse and replace it. Also check electicity wire. It looks everything is good, but no power and no light. It doesn’t work.
Does anyone have idea? How to fix it.
:mad:
Here are your parts includes a wiring diagram.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=HYE3460AYW
Not sure how you checked the power but you have to measure it with a meter.
If you do not own a meter then you can narrow it down some by putting the unit in timed dry mid cycle. The timer should advance if not then it is probably a power problem and not a machine problem.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
For your symptoms it is the L1 to Neutral, 120 volts that is important.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
