maytag dryer
dryer is squeaking or squealing very loudly when it is still cold…stops after it warms up…how do i check the pulleys? belt? Iddler?
If the squealing is comming from the drum
the best thing to do is replace the drum
support rollers, idler pulley and the belt
at the same time. When replacing the rollers
and pulley make sure the shaft that they ride
on is clean before putting the new ones on.
