No heat and drum doesnt turn Remove door switch & tie 1red wire &2 white wires together and everything works fine . door switch is new & ive bypassed all sensors I can find. whats wrong
Check the thermal fuse (5 on the diagram) for continuity.
- The thermal fuse/high limit thermostat kit AP4242472
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5172067
