maytag electric dryer
my dryer runs but no heat. the part 530771 looks new-no loose or burned wires. what else could it be. thanks
Here are your parts, includes a wiring diagram
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=cye2000aye
Could not cross reference this part (530771) so do not know what it is.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Next would be to check the heating element and the Safety thermostat for resistance.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
