Maytag LAT9605AAE Fills to High on high level
Not sure if it is worth fixing or not but the above model washer fills to the brim of tub on the highest water setting in the fill cycle. My guess is the presure switch is weak or going bad. Anyone elses thoughts would be most helpful. Thanks.
Try disconnecting the hose from the pressure switch and blow through it to make sure it’s clear of any obstruction. If you can hear air going all the way trough into the tub, the air way is clear.
Failure of the pressure switch is rare, but can occur. Confirm the problem by unplugging the machine while it is filling. If it continues to fill after unplugging, the problem is in the water mixing valve.
If, after clearing out the air way, the problem persists, I would replace the pressure switch.
Thank you. I will try that stuff before I buy anything. Thanks for your help. (Like that technical term "stuff"?)
