I have a Maytag Neptune washer that I repaired in February. I replaced the bearings and seal. Now the washer is leaking during the spin cycle. What needs to be replaced and how much trouble is it?
Regards,
RED
I found the problem. The drian hose came off the inner door boot. I attached the drain hose and clamp. It does not leak.
RED
Hello, make sure that you replace your faulty door latch wax motor if you have not done so yet. See http://www.neptunehelp.com for details. There is a video at http://www.neptunehelpsong.com that explains the issue. Also, the earlier MAH3000’s have (2) more of the faulty wax motors in the soap dispenser that will fail eventually. These control the softener and bleach flow.
