maytag leaking water and oil
hello all
I have an 18 yo maytag dependable washer. and im trying to determine if I should repair or replace… Its been a great washer with very littke trouble ( replaced a coouple hoses, belt and i timer thruout the years)
now i have water leaking from the tub seal ( i think) its from the bottomof the outer tub where the transmission inserts… the other problem i see is the transmission is leaking oil from the top??? do i nned to repace the tub seal and transmission?? or are there other trans missions seals to??
any advice would be apprciated
thanx
Mike P
