Unit leaks water during cycle from center bottom of tub where top of trans. enters/connects. Suspect a seal has worn. What is recommended to disassemble (what order) to gain access to and replace? Tub has 3 support brackets with heavy dampering springs all surrounding the trans. (inverse tripod shaped). Any info. would be appreciated. Thankyou, Dave.
Related topics
Maytag Washer Leak | 7 | 5113 | September 15, 2009 | |
Leaking Maytag tub | 1 | 1170 | May 16, 2010 | |
maytag leaking water and oil | 1 | 1974 | March 25, 2013 | |
Maytag performa washer | 2 | 2202 | October 23, 2009 | |
Maytag tub seal replace | 1 | 2457 | October 26, 2010 |
