maytag leaking
Have a maytag(LAT8426AAE) washer that has developed a leak from the bottom of the tub where the tranny runs through.will the tub bearing kit resolve this?The text says i should change the seal kit at the same time. what do I need to order? The IPB says it will need a spanner wrench to remove the spanner nut>
Change the TUB SEAL (stem&seal kit) don’t worry about the TUB BEARING!!!
Thanks Drags 1998
