Maytag mdbh945aww not working
I have a maytag dishwasher that all of the buttons on the front panel work except for the start and delay buttons. any suggestions?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDBH945AWW
Here is the tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Schematic%20-%20W10111827.pdf
Check the control panel (keypad) pin-out listing to see if the delay and start have a common circuit track (see the tech sheet). Then check them with a meter. If OK then control panel is OK and the control board is probably the cause.
You may want to try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
