Maytag Neptune front loader part question
My washer does not spin and when I took it apart the bearings were at the bottom of the washer. I order a lip seal kit. Does the kit come with a front and back seal?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MAH5500BWW
If you click on the picture in the list another view opens showing what comes in the kit.
Check out http://www.neptunebearing.com for more Neptune bearing and seal kits. They also rent a custom tool kit to help you change your bearings.
Don’t forget to change your faulty door latch wax motor if you have a Maytag Neptune MAH3000, MAH4000, MAH5500A or a 2000 stacker. See http://www.neptunehelpsong.com for more details.
