I have been reading on my issue around forums but need some help pinpointing what to do/replace.
My 10 year old washer has been flawless … until now. A family of five (with 3 girls) and its run daily all day for the last 10 years. They go through changing clothes like a family of 12. So I have to say I love my washer and the problem I have now I think is minor. Anyway…
Now it will start wash fine any cycle, hot/cold, warm/warm, cold/cold, and almost every time on the rinse cycle it will have no flow of cold water in the bleach/softener area and exhibit a buzzing (low audible) humming like sound as the component and a component is malfunctioning not allowing flow. The water line hoses have been detached and checked, water flows into a bucket at strong PSI so I know hoses are not clogged. Screens are clear on the washer inlets and no debris in them. This is a mechanical failure of a part I am 99% sure.
After water doesnt flow, and a short time passes of about 5-8 minutes or so, the washer beeps three times and the LCD display reads "The washer did not fill. If this continures call for service." Diagnostics mode menu indicates the expected "NF" (No Fill) error.
I have been limping along with this issue for a few weeks now. At first it would resolve if, after failure, I clicked the PAUSE button to re-start the failed rinse cycle and then it might work again. Soon it did it more and I figured out that if I would KINK the cold water line after I restarted the rinse cycle, then when the washer would turn the cold water inlet valve on I would feel the hose suck in and I would release the hose kink letting a surge of cold water to the washer inlet and sometimes that seemed to "help" a valve or something to trip thereby water would flow, if it did not, I could re-kink it and unkink it while the humming was going on… sometimes 3-4-5 times of repeating kink/unkink and the washer would open the valve and allow water in and it would start flowing in the softener/bleach area.
Now it is not really working as much anymore unless I let the washer sit 10-20 minutes or so, then come back and let it start up again. Sometimes the water flows by itself, sometimes I kink the line once or twice and it flows, sometimes it wont at all and I wait more time. Its slowly getting worse.
So if you are still reading, thanks. I wanted to post here for you experts to guide me in troubleshooting this or determining exactly WHICH part to replace as I dont want to replace a control board if the Water inlet valve is all that is the problem, nor do I want to replace the inlet valve if the pressure sensor valve is the problem… those are the only three things I have learned about regarding the NF code information.
Most of the information I have learned is surrounding the non-LCD MAH5500 model, which I understand is very similar to my MAH7500 LCD model.
ANyway, Thanks alot in advance!
