Maytag Neptune MAH9700 ND error, new pump
Repairing a Maytag Neptune washer that won’t drain - ND error.
Replaced the pump motor and receiving the same error. Ensured that there are not any blockages in hoses/boot.
What is the next test to determine if a control board or something else? I’m thinking a voltage test to the pump, but what is the best way to test with the voltmeter? Pump disconnected and directly to the harness, looking for 110vac?
Want to ensure that it is the control board before buying another part that may not have an issue. Is there anything else to check that may cause the ND error?
