Maytag Neptune won't drain, pump is good
Hi,
I’ve tried to trouble shoot my machine. It appears the pump is not recieving a signal to turn on. I took pump off and ‘plugged’ it in to 120v and it runs.
I can run a load IF I take the drain hose off, let it drain into the floor drain and raise the hose again when the machine is filling. So it seems like any sensors must be working because it won’t continue the cycle when the machine is full of water and it needs to drain.
I followed the Board Output test through and get no response when I get to the drain pump test. No voltage at the pump connector is shown either during this test.
I’ve followed the component Testing Procedures for sump sensor and get about a 3v reading. No luck on the Drain Pump test though.
Is there anything left to test, or does it look like I need a new board?
Thanks,
