maytag neptune reluctance motor
I ordered a replacement motor only for this washer . The old motor is the same physical size , etc . For wiring it has two connector plugs attached ; one 6 conductor , one 3 conductor . The replacement motor only has the 6 conductor .
The 3 conductor plugs into the control board at a different location . The 6 conductors connect at various points . Will this new motor work minus the 3 cond ?
