our maytag washer motor burned up. I ordered a new motor from appliancepartspros but the electronic connectors are the wrong size on wires coming from washer. also the switch on top of motor is color coded and on new motor/switch they are number coded. Also on old motor there are 3 holes for the mount studs to attach to base with the hole to the left of center being used on old motor , new motor only has a center hole and no left or right hole to mount to base.
Related topics
motor wiring question on maytag washer | 3 | 3686 | January 4, 2011 | |
maytag neptune reluctance motor | 1 | 4672 | March 31, 2009 | |
Improper wire connections new motor | 1 | 965 | May 9, 2012 | |
washer motor | 1 | 777 | March 27, 2009 | |
Order #616919 Switch Change | 2 | 1729 | March 28, 2009 |
