Maytag Neptune Soap Dispenser
:mad::confused:For the second time now the soap/bleach/softener dispenser on my front loading Maytag Neptune has broken at the plastic posts that the screws holding the dispenser to the frame go in to. Looking for a replacement part (shipping to Australia) and a way to prevent this from occurring again.
Thanks in advance for the help
Tom
tom@humanconcepts.com.au
Hi Tom,
Unfortunately I do not know who does ship parts to Australia. Maybe you can find a shipping address in US and then this person will ship it to you?
  • The part number for the dispenser assembly is AP252043
Barbara,
What is the original problem with the dryer?
We are replacing the starter switch. (Have the switch… just need to get to the old one).
Thanks!
Remove the screw from each side of the console. Pull the console forward and up to remove the tabs on the bottom of the end caps, out of the holes in the top. Lift the console up and lay it on its back.
P.S. If the dryer stops as soon as you release the start button then the problem is a bad control board and not the start switch.
Just did it this morning with a Kenmore 70 series. Assuming the 70 Series is constructed similarly to your machine:
Pull out the lint trap from the top of the console and remove the 2 screws. Pop the top cover up at each front corner using a screwdriver between the top cover and the body and gently pry up each corner until free. The top should now tilt backwards. At each front corner, about 2 inches from the top is a screw. Remove the screw from each front corner. Lift up a front corner of the washer and put your shoe underneath being careful to NOT catch your toes. Give the side panel, by the front where you have lifted it up by your toe, a good pop down with the palm of your hand and that front corner should separate from the side panel. Repeat at other front corner.
jmd_forest
The Brand Name is a RCA Model MSX 25 DR . I simply need to learn how to gain access to where the two heating elements are located .
The replacement parts number is AP2071465.
:cool:
