Maytag oven, three things wrong
Hi, I own a Maytag oven that has three things going on with it. It is a double oven & it makes a clicking noise at the control panel & the light in the upper oven keeps going on and off. Secondly the heat sensor light for the front right burner stays on even when the burner is cool to the touch. Thirdly I’ve started to get the error message F1-1 at random times. I can usually hit cancel & it stops, but it’s happening when I use the oven & I clearly need to do something. Sound like a control panel to you?
