Maytag Performa makes high pitch noise
Maytag Performa makes high pitch noise.
Tilt it back and remove the belt. Turn the pump (the smaller pulley) in both directions by hand. If it makes noise, replace it. Tell us what you find.
Today I removed the belt and turned the pump pulley and it has that "grinding" noise. I am going to order the pump this afternoon from applianceprtspros.com. Thank you "Magician59" for the advice. God bless you!
I just replaced mine yesterday. I waited too long to figure out what was making the loud noise and my whole washer seized up in the middle of the spin cycle and made a nice burning smell. Good thing you caught it early. Good luck.
Water is not circulating through either the lower or upper arms of my Sears Elite dishwasher, Model No. 665.15982990.
I can hear the pump running but it appears it is just recircing water around the bottom with none being forced up in the spray arms. It fills and drains normally.
I removed and cleaned the strainer on the bottom. While putting it back together, I can’t see what holds what I’ll call the upper pump housing from the lower. I don’t see any broken parts. Could this be the problem?
