[SIZE=3]Desperately seeking help.[COLOR=Black] 3 women without a washer [/SIZE][/COLOR]machine comes close to a crisis. Top loading washer machine problem is
[B]no water coming into the washer holding tub. When you turn the dial, only cycle that works is the SPIN cycle.[COLOR=Blue] Could it be the water inlet value or perhaps a fuse? Please advise and any diagrams, advice on how to find the problem and part number location so we can order a part? [COLOR=Black]We are deeply grateful so for your professional help.Thank You.
[/COLOR]
[/COLOR][/B]
before you call the repair guy, before you try to fix the timer, valve or water inlet please check the Fuse, I had the same problem but some extremely helpful post on the net from this guy ( thanks to him) I just replaced the fuse and the washer came back to life! Everything was working other than filling just because of the fuse which activates the water pump!
[/COLOR]
[/COLOR][/B]
