My washer fills but will not agitate, spin, or drain. My husband installed a new lid switch about a month ago because the machine stopped working mid cycle. It worked great for about a month until last night. Could the lid switch be broken again or what else could be causing this to happen? Any help would be appreciated.
That sure sounds like the lid switch has gone bad again. The switches on these models are known for being unreliable so it is entirely possible that may be the problem.
There may also be a fuse in there, so check to see if there is and if that is the problem.
