Washer fills with water and overflows does not stop filling Big mess:mad:
Hi.
Does the water stops if you turn the washer off?
Please provide the complete part number.
Simon.
— Begin quote from Simon / APP Team;772287
Hi.
Simon.
Yes the water does stop when we push the settings knob in. machine won’t agitate but will spin out when put on spin I don’t have the part # handy I can’t get it until Sat thanks Tom
Please do so.
Simon.
— Begin quote from Simon / APP Team;772368
Please do so.
Simon.
Good morning the model # is PAV2300AWW Thanks for any help Tom
Hi.
Check the pressure hose for cracks or small holes
And if it looks OK - replace the pressure switch
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46634
Simon.
Thanks for your help when I took cover off the hose was not attached. reconnected the hose at bottom put back together, and it worked thanks again… Tom
You are welcome.
I’m glad it was an easy one.
Simon.
