Maytag washer will not fill
Maytag washer will not fill on cycle start will only fill on rinse cycle, on all settings (reg, delicates, easy care)??
Looking at the timer diagram on models similar to yours suggest that the timer is the problem, since the cam and contacts are the same for all fill functions on all cycles.
I would replace the timer and see if that does not solve your problem. I would also call in the order with your serial number to make sure you get the right one.
I have a frigidare washer and when i turn the knob to start it,it does nothing. water wont run in,it wont spin,nothing happens. All lights come on. I purchased a control board from you a few days ago thinking that was the problem but still nothing has changed. what do you think?
Perform the troubleshooting as described in the Tech sheet. Post the results.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5161297
